2 members (Guitplayer, Denny Graham), 78 guests, and 4 robots.
Topics128,194
Posts1,057,261
Members48,466
Junior Member
Junior Member
... How can I post a reply to a poster in the middle of a thread? Anytime I want to add a reply, it goes to the bottom of the thread.
There are times where I would want to reply to the 5th reply but don't know how to zero in on his reply?
52 Chebby
Ex Hall Monitor
Ex Hall Monitor
Click on the quote symbol along the top of the post. Your reply will still be at the bottom of the thread but it'll show that you're replying to the quoted text.
Ex Hall Monitor
Ex Hall Monitor
Quote
52 Chebby
This is an example.
like this>>>>
Quote
if you click the [img]http://www.stovebolt.com/bboard/ubb//quote_ubb6.gif[/img] right above the persons post you'll be jumped to the full reply form with the person quoted in the text box, then you can make your point and it will be obvious who you're yappin at grin you can also edit out things to make it clearer, as I did above
and yer always welcome to post questions about how the forums work in the IT ShortBus
Tiny beat me, so here you can also see how to edit a post, using the [img]http://www.stovebolt.com/bboard/ubb//edit_ubb6.gif[/img] icon grin
Moved to IT ShortBus
