1 members (TooMany2count),
120
Mod | | | Forums66 Topics128,193 Posts1,057,257 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 9 Junior Member | | Junior Member Joined: Nov 2006 Posts: 9 | ... How can I post a reply to a poster in the middle of a thread? Anytime I want to add a reply, it goes to the bottom of the thread.
There are times where I would want to reply to the 5th reply but don't know how to zero in on his reply?
52 Chebby | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Click on the quote symbol along the top of the post. Your reply will still be at the bottom of the thread but it'll show that you're replying to the quoted text.
| | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Originally posted by 52 Chebby:
52 Chebby This is an example.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | like this>>>> Originally posted by 52 Chebby: ... How can I post a reply to a poster in the middle of a thread? Anytime I want to add a reply, it goes to the bottom of the thread.
if you click the [img] http://www.stovebolt.com/bboard/ubb//quote_ubb6.gif[/img] right above the persons post you'll be jumped to the full reply form with the person quoted in the text box, then you can make your point and it will be obvious who you're yappin at  you can also edit out things to make it clearer, as I did above and yer always welcome to post questions about how the forums work in the IT ShortBus Bill Tiny beat me, so here you can also see how to edit a post, using the [img] http://www.stovebolt.com/bboard/ubb//edit_ubb6.gif[/img] icon  | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | |
