1 members (2-Ton), 150 guests, and 0 robots.
Topics128,110
Posts1,056,241
Members48,437
need this in a hurry no time to search any more
what is the rear axle width of 49 3100 hub face to hub face?
thanks
yea i saw that site but i cant see actual axle face to face width just tyre centers??
My 54 3100 is 62 inches hub face to hub face.
thanks buddy
do you know if the front is the same?
62 is wider than i was expecting
was thinking 55-57
Tire centers is going to be real close to the same as hub face to hub face. I don't have an actual measurement at hand, but the 62 inches is about what I would expect.
The front is narrower.
ok guys thanks was looking at an axle swap but couldnt get to my truck
An easy swap for the rear is a late 70s-early 80s Camaro 10 bolt. I understand the 12 bolt GM will work as well. Measurement is 62 inches on my 51.
~Jim
My front axle from where the wheel mounts from one side to the other was 58 3/4".
Just measured my 1951 3100 rearend. It measures 62" hub face to hub face.
1951 3100 Chevrolet
ok thanks so whats the measurment of the springs ?the distance from outside to outside rear spring leaves im trying to see what axle choices i have locally (u.k)
i got one 50 internal and 56.5 external maybe add some inch spacers?
