0 members (), 136 guests, and 2 robots.
Topics128,035
Posts1,055,560
#227747 02/21/2007 2:09 PM
Junior Member
Junior Member
Hello,
My name is Michael Gardner and i am from the small town of Trenton,Ky. I have always had a thing for older chevys and thats why when i first got my lincense i chose to buy a 1965 Chevy C-10. Well im 18 now and im on my third vehicle. Of course my first one was the 65 C-10 and after a few months of it i wrecked it into a tree and telephone pole, but the damage only occured to most of the bed and the frame is now garbage. Since then i have been through a 84 Monte Carlo SS which i just sold a few months back for my 2000 Chevy S-10 because i needed to save on gas. I still have my 65 Chevy sitting in our garage and ive been thinking about trying to get it back out on the road but before i can ever do that i need to find a new frame for it. My question is what years and models of trucks would my truck be able to swap over to. The only thing i would mainly be switching over is just the cab as i plan to scrap everything esle. If you could help that would be awesome.
Thanks, Michael
#227748 02/21/2007 9:21 PM
Your only direct swap will be with a 64-66. Cab mounts changed in 67. If you're wondering about swapping to a newer frame, someone else will have to help you.
Welcome to the bolt.
Fred
52 3600
69 C-10
#227749 02/22/2007 2:32 AM
Z
Z Offline
id say maybe 1963-66.if its a long bed,it should be easy to find a frame.if you were near me i have one id give you to get it out of the yard.
#227750 02/26/2007 7:01 AM
I agree with these guys if you're wanting to keep it as close to original as possible... if you are not... heck why not go all out and put a 88 or newer frame and running gear under it?
I DO know that if you have the stepsdie bed... (doesn't matter if it's long or short) you can go all the way back to 55.
Best of luck.
Boogity, Boogity, Boogity Let's go racin boys.
Drive fast, turn left. GO #20.
Real trucks where bowties.
#227751 02/27/2007 7:51 AM
The frames from 63 to 87 will swap if my memory serves me correctly. I don't know all the details on it, but I do know that the later axles are a little bit wider than the 63-66 frames and the cab mounts are different. The later frames 73?-87 will give you front disk brakes and power steering. Try searching the engine and driveline forum on 63-66 frame swap. Someone will come through here and probably correct me...
