| | | Forums66 Topics128,012 Posts1,055,320 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 75 | I have a 65 c10 that i am restoring. I have found a 64 cab.My question is will it bolt right up,or are there any mods that need to be made? anyone got an idea?
"you can't fix stupid"
| | | | | Joined: Nov 2005 Posts: 266 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 266 | | | | | | Joined: Jun 2006 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 75 | thank you 66. I was just concerned as the 64 I may get has the removabe hup.Any ideas what that is/was for?
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | The 4 speed & 4x4 trucks had the higher removable trans hump. Brian | | | | | Joined: Jun 2006 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 75 | gotta be the old 4 spd then. Pulled up the vin, and it lists as a 2wd. thanks again for all the info. .........
| | | | | Joined: Feb 2007 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 53 | i went to the local wrecking yard the other day and they had three early 60's chevy trucks in the yard, not much left tpp them and sadly to say the fella who operated the fork lift did not take it easy on the cabs, two of the trucks roofs were pulled almost off the cab, if anyone wants anything just let me know and i will check it out and see if the wrecks have a good part... | | |
