4 members (delwrench, tclederman, MRMEROTH11, MNSmith), 68 guests, and 5 robots.
Topics128,190
Posts1,057,223
Members48,465
I recently re-adjusted the valves on my 1975 350, they were all at 1/4 to 1/2 turn past "zero lash"... where the book setting is 3/4 turn past "zero lash"... during the test drive, i didnt detect any difference in performance...
comments?
Another quality post.
Real Trucks Rattle
Loose is better than too tight(as far as valve adjustment goes).Too tight will hold the valve open(pump up)on a high rev.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
Rusty Rod,
I don't think it is critical. Once the lifter is pumped up, it in essence becomes a "solid hydraulic lifter". I think the recommended adjustment positions the piston in the center of the travel inside the lifter proper, and this is what the engineers want. As long as it is close...not bottomed out and not clacking, you are OK.
This is my understanding of it, but I might be OTL.
Stuart
The reason for giving another 1/4 to 1/2 turn after the lash is taken up is to get the piston in the hydraulic lifter in the middle of it's travel. I have learned that going to 1/4 turn or less makes the lifters less likely to pump up at high rpm's.
I have used this method for hydraulics on my daily driver for years. Valve adjustment
On the road every day...
1952 Truck - 235
1948 Coupe - 261
To follow up on this question, how does this question affect those of us with solid lifters?
Not to steal the thread Rusty, but I just went through a similar adjustment issue and this has been a helpful primer.
If it ain't broke, take it apart and figure out why!
39 Chevy in the Gallery
Photobucket Album
39 AZ 3/4 Ton,
With any solid lifter, the side to err on would be loose. You can visualize the valve train being tight, heating up and holding the valve a tiny bit off the seat...soon, the gases have eroded a channel. The hot valve gets it cooling from coming in contact with the seat in the water cooled head.
Solid lifters are adjusted to a specific clearance as opposed to calling out one turn, or 3/4 of a turn etc. Was this the question?
Stuart
Rusty Rod,
Just for my own curiosity I measured a 3/8" NF bolt through the under head to under nut dimension, then turned it 1/4 turn more! Less than .013 thousandths travel...not much more than a RCH! wink
Stuart
A solid-lifter cam has a more gradual acceleration ramp, before the valve actually starts to lift. ideally, the clearance should match this area of gradual lift. It's easy to figure out with a degree wheel and a dial indicator. Otherwise, just try to stay with the cam grinder's clearance specifications. A slightly loose adjustment with a solid lifter system will be a little noisy, but that's better than running out of clearance once the engine warms up.
Thanks for the input.... this engine has hydraulic lifters... and i was just wondering how much, if any effect, a half turn on the adjustment might make on performance.
I'm thinking as long as they are not too tight and not clattering, they will be good..
Real Trucks Rattle
Hotrod Lincoln , I've always been told that on a cold engine ADD .002 to the number that ya want to adjust to for a hot engine ....
Any thoughts . Solids are the ones in ? .
Thanks , George Hood
1965 C-10 fleetside shortbed BLACK
82 c-10 longbed 6 cyl.
58 Lincoln 2-dr coupe Black w/white & blk.
59 lincoln 4-dr. parts car
Quote
That's how I do my hydraulics.
Tightening the screw right after it stops clicking will give it an additional 1/8" turn anyway - perfect.
Just as long as the push rods are spinning you should be good for thousands of miles without any re-adjustment necessary.
If they don't spin - you are too tight and wear will increase.
1952 Truck - 235
1948 Coupe - 261
