4 members (Gdads51, Hanks custodian, MickeyP, homer52), 114 guests, and 6 robots.
Topics128,089
Posts1,056,137
Members48,435
Page 2 of 2 1 2
Alan sounds like we could ask are we having fun yet? You have certainly got a lot of very good help from these posts. After I read thru them, knowing you have a running engine that backfires, it reminded me of a game some of us did in a younger part of our life. We would turn the ingnition off for a few seconds and then back on as we were driving along. Guess what happened,
Yes in exploded the fuel buildup, destroyed the muffler, it swelled to the floor beating size. Is it possible that the Ignition switch/wireing, is turning of and on very fast? How to find out. Hot wire it, Take a piece of wire from the positive post of the batt. If it has one in the system put in a ballast resistor Attach it to the + side of the coil, takeing the other stuff off and see what happens. If it still backfires the problem is in the Dist. If not it is in the switch/wireing leading to the Dist. Just a thought, hope it helps.....Chb46
Thanks chb and bald I didnt turn the engine over with the dist out. But darn if I aint gitting a lesson in electrical wiring 101. laughing.Just glad its a truck and not my house.WE will whip this critter by next week and i can post that my dogs dont need any more tranquilizers from the backfires.lol
eek :rolleyes: grin
Live every day to the fullest for tommorrow never comes!!!
Red dot, center of chest ...
All this time I've neglected to give Paul's cardinal rule for automotive repair. If you're not sure what's wrong, always replace the cheapest parts and do the easiest work first!
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
#22696 01/19/2002 10:11 PM
Ty Paul Great tip laughing eek eek :rolleyes:
#22697 01/20/2002 12:15 AM
Anonymous
Unregistered
Anonymous
Unregistered
baldeagle Never assume anything. grin I have seen guys lean on the fender and move the truck a few inches and turn the motor just alittle bit in gear. Just did not want him to think it would only go in 2 ways(as some motors do) grin SAs far as the ballast resistor is use the chryler ones and never had one fail.They will fail if you leave the key on.My bet is the point also. wink Well its finally snowing like a ..........well you know .Off to play in the snow all nite .John you got that Doge all warmed up??? :p
OK phat your right,. I was thinking off top of my head when alan said distributor would only go one of two ways, I thought he had blade type distributor gear drive oil pump,sorry bout that.
Alan did you get it to run right?
jbennett
40 burb
JB
Pulling the second of my 2 12 hr shifts no it isnt fixed yet ,probably be Tues before I can get back to it. got to work to pay for it laughing thanks
i'll put all my vitual money on bad coil, bad ground, or bad condensor. knowing about his Pueblo episode,, i would also guess his spark plug wires on the distrbtr are reversed but i don't think the engine would run at all. My truck was stumbling pretty bad once and my buddy says "well lookit that uglee color spark,,," and i said,,, "yeah".....
Luz
I wouldnt trust your opinion from Centennial anyhow, but thanks for trying to make a south side kid try to believe in you (laughing) Thanks
Alan
Page 2 of 2 1 2
