2 members (TUTS 59, Mike B),
126
Mod | | | Forums66 Topics128,283 Posts1,058,504 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#22621 06/17/2003 1:15 AM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | What are the effects (if any) on the exhaust sound when mounting mufflers away from the collectors (towards the rear) on a system with long primary tube headers as opposed to doing the opposite (mounting the mufflers closer to the collectors)? Thanks! | | |
#22622 06/17/2003 12:26 PM | Joined: Jan 2000 Posts: 206 Member | | Member Joined: Jan 2000 Posts: 206 | Generally, the longer the tailpipes, the quieter the entire exhaust will be, but this depends on a lot of other things. One is cam timing; a cam with little overlap will cause "rap" on deceleration. The longer the tail pipe, the more pronounced this will be. With more overlap, i.e, most performance cams, this effect will diminish. | | |
#22623 06/17/2003 2:21 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Exhaust gases cool as they travel down the pipe, so its been found that mounting the mufflers as far rearward in the chassis causes two benefits: Less heating of the mufflers, and since the exhaust gas is a little cooler, the size of the tailpipes is less critical. A larger case (size) muffler usually deadens sound and flows better on a given application.
The placement of mufflers, pipe size, and system configuration (H-pipe, X-pipe, Y-pipe) all depends on engine & header parameters, the purpose of which is to achive the elusive "tuned" exhaust.
As far as just 'sound' I'm curious how muffler placement afffects it. It just depends, as the obtaining of the resonant frequency of engine exhaust in its powerband depends on distance of mufflers from collectors. Prolly the presence of tailpipes quiets any system down from there.
Thats my SWAG anyway.
Chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
