9 members (artinva, Gdads51, 1955 1 Series, tesa, JW51, Peggy M, VicZ, Ridgeback, 1 invisible),
93
0
Mod | | | Forums66 Topics128,077 Posts1,055,932 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 51 | Hi Guys
Has anyone put a booster from CCP in a truck?
I need some help with installing a power brake booster in my 55 1st serie 1/2 ton Chevy truck. The Booster is from CCP. The booster is right now mounted on the frame but the rod that comes out the booster/cylinder that needs to be connected with the brakepadelarm doesn't meet the arm right. It kinda comes from an angle and I don't trust to just put a bolt through to connect it. The original rod from the cylinder is screwed on a U-joint which is mounted with the brakepadelarm. Hope to send a picture if that doesn't make sence. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Bernd, I have installed two of these units so far, I'm not sure who the supplier was [ supplied to me by customers ]. I had to modify both of the mounting brackets, I had to cut the mounting feet off of both of them to make them fit properly, one was on a 52 one ton and the other was a 49 half ton. The frames on these trucks constantly taper from back to front, and it looks like the brackets are made to work on frame rails that are parallel. AS far as the attachment to the pedal I had to use a spacer between the hiem joint and the pedal arm, hope that helps. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I have posted pictures of what it took to get the CPP bracket to fit. Click on the link below, then "54 GMC", then "Front suspension". It's toward the bottom of the page. | | | | | Joined: Apr 2006 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 51 | Thanks a for the imput Just one thing, I tryed to get the http://jbhardin-gallery.com/trucks webside to work but I couln't. Is there a other way to get the pictures? Cletis if you don't mind send it to my e-mail adress Thanks | | |
