4 members (David1927, Gdads51, Guitplayer, Wally / Montana), 85 guests, and 2 robots.
Topics128,264
Posts1,058,357
Members48,485
#22570 04/12/2002 2:04 AM
Does anyone know the purpose of the coil spring that sits in the groov around the outside of brake drums? I have a 58 Chevy Stepside and only 1 of the drums has this spring but all drums have the groove for the spring to fit into.
Also, does anyone know a soucre for these springs? I have not been able to locate any in the catalogs.
PS Sorry for this very minor question amoung all the great questions but I am new to restorations. :p
#22571 04/12/2002 2:31 AM
You know, I had two of those, did not know it was a common thing, maybe from the factory? I don't know the answer, but will keep my ears open for the answer!
#22572 04/12/2002 3:16 AM
The spring reduces vibration and ringing from the drum. Same reason a leather or rubber belt is wrapped around a drum when it is turned on a brake lathe
I dont know if anyone offers the spring. If you are having no problems, don't worry about it.
#22573 04/12/2002 1:23 PM
If you do need a spring for this use, you can use a old fashion screen door spring for the closeing of a screen door. Thay still make them and can be purchased at your local hardware stores.
37 Chevy 1/2 Ton
86 Chevy Blazer
98 Drudge 24 valve Cummins
One worn out Timberjack
