| | | Forums66 Topics128,020 Posts1,055,345 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | '54 GMC with a '56-'57 Chevy 235. Temp gauge wire is severed. I had assumed that this was a capillary (mechanical) unit. However after looking more closely, the wire coming from the gauge is solid-not a hollow tube. Its like a solid core wire except it looks like brass and not copper. The wire is soldered to the gauge, which has no other leads to it. I do have a sender that I pulled from the head but I don't know what is supposed to connect to it. Does this sound familiar to anyone, or does someone have a picture or diagram of what a complete system should look like?
Thanks | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It has to be a mechanical unit. GM didn't go to an electric temp guage until '56, then it was mid year on that chenge for the 235. However, the secription you give for the hookup for your guage is correct for a mechanical, the capillary tube kind of looks like a peice of bare solid core wire. Another clue is only 1 hookup at the guage. The electric guages have 2 leads, usually 18 guage, one for the power, and one to the sending unit. You might also notice a funny smell form the severed end. That would be the ether that originally filled the tube.
Bill Burmeister | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the hole in the capillary tube is tiny, when cut the hole will be invisible so the tube will appear to be a "wire" .... as Bill sez, the gauge is mehanical, but because the engine is 56/7, the sender in it will be electrical ...
Bill | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | | | |
