11 members (Eisenholtz, Gone, Peggy M, Donf, Otto Skorzeny, Wickedbass, Hawkman, NJC, GRNHydra, hdgeren, 1 invisible),
72
Mod | | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#22538 04/16/2002 1:04 PM | Joined: Aug 2001 Posts: 16 Member | | Member Joined: Aug 2001 Posts: 16 | Got the 1961 235 in 48 Chev pickup using the stock 3 speed and bell housing. Had the radiator recored to 4 row in the stock position. The new 235 short water pump is 1 1/2 inches from the radiator and sit lower than stock 216 did. WHAT fan has been used with this set up and will it work in the low position?
L. Day
#22539 04/17/2002 3:59 AM | | Anonymous Unregistered | | Anonymous Unregistered | late 50's 235 fan blade should work. Depending on your application... If you are using Patricks S.S. water pump it is sometimes necessary to flatten the fan blade ever so lightly to clear the radiator & harminic balancer . On the other hand it is sometimes necessary to shim the fan blade away from the waterpump pulley & closer to the radiator so the blade clears the harmonc balancer. Use the shortest flatest 4 bladed 235 fan blade you can find & fine tune the temp with the thermostat. If your new 4 core radiator is thicker than the original radiator, it may be tricky getting the fan blade installed without hitting either the radiator or the harmonic balancer. | | |
