8 members (Bill Hanlon, Waveski, Jon G, Pre '68 Dave, 3B, kades51, 2 invisible),
126
Mod | | | Forums66 Topics128,283 Posts1,058,513 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | There seem to be many idiosyncrasies surrounding Canadian built bolts. Was there an actual General Motors/Canada...was it part of the stateside GM or a independently run company.
Did these two companies talk to each other...why are there so many differences between the two engines..BIG differences. :confused:
Stuart | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | GM Canada was originally McLaughlin Motors, which made some deals with Durant to produce McLaughlin-Buicks and Chevs, and was eventually bought out by GM , but kept some autonomy - the differences weren't inside the engines, just in what engines were used - today they're pretty much the same, and some models are only made in one country or the other, but sold in either Bill | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | the truck model numbering is different eg.american 3100 is a 1300 in Canada my truck is Canadian built model 1304. | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | Some interesting things I've found about Canadian GMs. In the US, the 1954 Buick Special came with a specifically cast 264ci engine. The heads, crank and all sheetmetal and accessories interchange with the larger 322 found in Century's, Supers and RoadMasters, but the block and pistons were specific. And, the block was not simply an under-bored 322; the 264 can NOT be bored to 322. They made a specific block. And the 322 could not be ordered in the Special. Canadian Specials came with a 322.
I saw a '62 Pontiac station wagon for sale once, with a 409 in it.
And my favorite: Pontiacs up there also came with small block Chevy's; for a couple years (either the late '50s only, or up into the very early '60s), the "script" valve covers on the Pontiac engines had "Pontiac" embossed in them, just like ours down here had "Chevrolet" embossed. I'd like to have a set of those!
And then of course there's the Ford side of things, where the Ford F1 and F100 trucks wore Mercury badging. Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | and the Dodge trucks were Fargos I've had 283's here with Pontiac decals on the valve cover Bill | | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy guys, the Canadian Pontiac was actually a Chevrolet chassis with shrunken American Pontiac style sheet metal, a totally diferent vehicle from its American cousin. Many interesting differences between vehicles produced in our two countries in the 40s-50s and 60s. | | | | | Joined: May 2002 Posts: 144 Shop Shark | | Shop Shark Joined: May 2002 Posts: 144 | The Canadian Pontiac's 1955 to 1961 came with a 261 inch 6 cyl. as the basic engine.I have 2 of these engines. I think they are just bored out 235's These full size Pontiacs were huge with only that six to pull them around. Ter | | | | | Joined: Nov 2006 Posts: 87 Member | | Member Joined: Nov 2006 Posts: 87 | Pontiac V8 engine From 1955 to 1981 the Pontiac Division of General Motors manufactured its own, unique V8 engines. Displacement began at 287 in³ and grew as large as 455 in³ (7.5 L) by 1970. An engine of intermediate size (neither a true small-block nor big-block), the Pontiac V8 was a unique design, distinct from Buick, Chevrolet, or Oldsmobile engines. Pontiac's engines were used in its U.S.-market cars; Canadian Pontiacs generally used Chevrolet engines. From 1955 through 1959 Pontiac's V8 was also used in GMC pick-up trucks.
The 287-V8 engine was introduced for the 1955 model year as the "Strato Streak". Not long before the model year introduction, Pontiac management decided that the entire line would be V8-powered.
Toxictiki
'59 Apache 3100 panel (235) '51 Chevy Fleetline Deluxe (216) '48 Binder KB-1 (flathead 6) '77 Cadillac DeVille (425 donor)
"Once I was 'Chairman of the Bored' then I bought a Stovebolt."
