2 members (rick46ia, NJC),
112
Mod | | | Forums66 Topics128,260 Posts1,058,343 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#22441 12/24/2004 11:37 PM | Joined: Apr 2004 Posts: 42 Apprentice | | Apprentice Joined: Apr 2004 Posts: 42 | Will the distributor from my 216 fit my rebuilt 235.
Thanks, Kelly 53 5 window rusty red 3100 | | |
#22442 12/25/2004 12:21 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Starting in late 1954 chev changed from a steel cam to a cast cam. They also changed the distributor gear material to match the cam. I have seen 216 distributors used in 235s but they seem to have premature gear wear. If you want to use a 216 distributor it is easy to swap gears.
See the USA in your vintage Chevrolet! My Blog | | |
