| | | Forums66 Topics128,192 Posts1,057,251 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 34 | I have a 1948 AD truck and a 1973 shortwheel base c-10.has anyone ever done a frame swap on these? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Track width is much to different to look good. I believe the same thought was discussed about a month ago, try the search function to find it. Grigg | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Yea.. i'd think the '73 C10 would be way wider than a '48 1/2 ton.
Now if you're talking a '48 ton and a half or two ton truck, I think the front fenders on those trucks are much wider, so that might not look too bad.. if you had the right size tires on it, anyway.
