| | | Forums66 Topics128,049 Posts1,055,695 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 26 | I have a 1950 truck, How does the radiator support bolt to the frame? Its been so long since I removed it and when I set it back up on the crossmember it didn't seem to fit right. It looks like something might go between the frame and the support Thanks -Roger [img] http://i15.photobucket.com/albums/a384/norm84/radsupport.jpg[/img]
'50 Chevy truck 1/2 ton
| | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | NORM84 there should be a flat peice of metal that goes between the frame rails, and the radiator to the grill to deflect the air into the rad DS | | | | | Joined: Jun 2005 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 26 | Thanks for the reply, I figured there must be something. I just don't know what it looks like. The holes for the radiator support and the frame do not line up like you think they would. If anyone has a picture of the piece of flat metal in question let me know -thanks
| | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | norm84 When i get home tonight I willsend you a pic of the tray behind the grill that you are looking for then you will have a visual reference of part and location DS | | | | | Joined: Jun 2005 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 26 | Thanks for the pictures and advice, D Sinclair the more pictures the better! Ive got it down to the frame and I am looking forward to start putting things back together.
| | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Norm,
It sounds like you want to know what goes inbetween the 'rad support' and the 'crossmember' as robin showed. The piece DS is talking about has nothing to do with bolting the rad support down.
I'm curious aswell since my rad support has no steel spacers that robin's pictures showed. I just put a rubber pad (bout 1/2 inch thick) in between.
Good Luck | | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | Roger you were transmitting and i wasn't receiving as colin says. the tray I was thinking of is forward of the rad DS | | | | | Joined: Jun 2005 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 26 | Ah I see I took a good look at it and searched through a couple magazines and I think I figured it out. There is one piece of metal shaped like this \_/ under the 'rad support' with two bolts that go thought it. You can see two of the pieces in Robins pictures. The 3100 has one in the center. Chevy Duty sells a rubber pad that goes beneath the \_/ piece of metal. As far as I know thats it Just the two bolts in the center bottom of the support. -Roger
| | | | | Joined: Nov 2005 Posts: 123 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 123 | norm
I just went through this with mine. There is supposed to be a shim in there. I made mine from some metal stock 1/8". I found I needed 1/4" in height. This has a direct bearing on how the front fenders align with the radiator support. Just that extra 1/8 made all the difference in the adjusting of fenders to the hood. If you have the shop manual it shows this in it. Ed | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well Roger, it's taken me two days to get the image into the computer, but unless I'm missing something I think this is what you’re asking about. The illustration is of a '54 with two mounting points, however the ’50 should be about the same but with one center mounting point. It is out of the Factory Assembly Manual, sec.11, sheet 2.11 for a 3100 & 3600 series. There were two 3/8” struts bolted at the top to each side of the core support and at the bottom they bolt through a doubler on the lower baffle. Mine (‘50, 3604) has a rubber cushion on either side of the cross member and body shims as required. http://rides.webshots.com/photo/2188142130098611668DjAgDv Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jun 2005 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 26 | Denny, Wow thank you very much! It is decided, I am getting one of those books. Thanks again Bolters
