3 members (Otto Skorzeny, Jeff Ogden, 78buckshot), 45 guests, and 5 robots.
Topics128,012
Posts1,055,316
Members48,419
#22209 09/12/2003 7:52 PM
Can anyone tell me what transmission came in a 1950 Chevy 6400 truck? I am replacing the closed drive line rear end for an open drive line in my 1/2 ton GMC. Before replacing the 6cyl., I would like to drive the truck to dial in the steering and braking. Will the transmission in the 6400 bolt to my 228 and work with the Camaro rear end that I am putting in my truck? My truck is currently running a 3-speed tranny. Thanks in advance for your help.
Phil
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
#22210 09/12/2003 11:18 PM
That would be an SM420, and it will bolt to a GMC bellhousing.
Paint & Body Shop moderator
#22211 09/13/2003 2:12 AM
Does the tranny out of the 6400 you are referring to have the park-brake assembly on the rear of the tranny?
You may need to have a driveline adapted to it but it can be done cool
