| | | Forums66 Topics128,089 Posts1,056,117 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#22183 12/01/2001 6:52 AM | Joined: Nov 2001 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 46 | I rebuilt the stock Bendix Stromberg 2bbl carb for my 305E this week. (The accelerator pump was not working) Upon putting everything back together I noticed that when the choke is fully open (no choke) the accelerator linkage does not rest upon the idle speed adjustment screw. I took some Polaroids of the carb before I began to make sure that it all went back together, and am fairly confident that everything is correct. The carb works fine, idles fine, runs fine, but I know that in order to have the full range of idle speed adjustment, the linkage needs to rest up against that screw. Yeah, I ran the screw all the way in. Any thoughts?? :confused: | | |
#22184 12/03/2001 7:45 PM | Joined: Jul 2001 Posts: 140 Shop Shark | | Shop Shark Joined: Jul 2001 Posts: 140 | On the bendix-stromburg, the choke linkage has a long arm with a fork on it that sits on the throttle shaft. This arm sits up against the idle adjustment screw, and if the fork isnt sitting on that shaft, the linkage wont match up. If that isnt it, than maybe bindage in the butterfly valves? Good luck. By the by, I have been looking for a carburator rebuild kit for my stromburg. Where did you get yours?
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht- Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
#22185 12/04/2001 12:16 AM | Joined: Nov 2001 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 46 | Got the kit at NAPA, part # 2-5111. Think the problem is more along the "something's binding" thing. All the linkage is setup correctly. What should I use to lube the throttle shafts and other linkage?? After doing the rebuild kit the truck starts a lot easier and runs great!!
Scott | | |
#22186 12/04/2001 12:23 AM | Joined: Jul 2001 Posts: 140 Shop Shark | | Shop Shark Joined: Jul 2001 Posts: 140 | try either liquid wrench or a carb degunker. Either should work. Just spray it on the shaft and down the carb, then open and close the throttle by hand, and it should loosen it up. If it doesnt, there might me an obstruction keeping the throttle from closing. Sometimes the gasket between the carb and the intake wasnt manufactured correctly and it will be in the way of the valves. Good luck. Thanks for the napa number.
Jonathan S. Keffer
#22187 12/04/2001 1:48 AM | Joined: Nov 2001 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 46 | Ahhhhh, ya know, there were some minor differences in the "lower" gasket...I'll try to take a closer look. Thanks again.
Scott :rolleyes: | | |
