1 members (Snowman51),
94
12
Mod | | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 44 | I have numbers from a 6 cylinder Chev. I need to find the engine size and year. The numbers are " f0504tpt " I don't have access to the engine, was given these numbers over the phone. Can someone help? thanks..
Hello, Welcome to America press '1' for English Puess '2' to disconnect until you learn to speak English
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The code come up as a '72 250, Flint plant, used in 1/2 and 3/4 ton 2 and 4 wheel drive whith manual trans.
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 1 Junior Member | | Junior Member Joined: Apr 2005 Posts: 1 | I ALSO NEED HELP ON AN ENGINE CODE, IF YOU CAN THANKING YOU IN ADVANCE MY MOTOR NO.,013125EF54Y | | | | | Joined: May 2005 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 44 | Longbox, Thank you. Was kinda hoping to find another 292 maybe but sure didn't want the 230, so this is good. This motor is closer to home and costs even less so things are just dandy..Thanks again
| | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | Jerry, Turn off your cap lock. You'll get a better responce.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | F54Y and F54YE are 1954 235 cubic inch Powerglide engines (hydraulic lifters) made in Flint, Michigan (1500 series Panel Delivery).
EF54Y is not in the truck ID numbers book that I have. Maybe someone else has better information that includes 1954 passenger car engines.
Tim | | | | | Joined: Jul 2003 Posts: 159 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 159 | Hi All, Here is some engine serial number information for Chevy Trucks and Cars. Cheers! | | |
