3 members (Otto Skorzeny, 3B, 1 invisible), 38 guests, and 7 robots.
Topics128,012
Posts1,055,321
Members48,419
#221572 12/12/2006 5:13 AM
I have numbers from a 6 cylinder Chev. I need to find the engine size and year. The numbers are " f0504tpt " I don't have access to the engine, was given these numbers over the phone. Can someone help? thanks..
Hello, Welcome to America
press '1' for English
Puess '2' to disconnect until you learn to speak English
#221573 12/12/2006 5:25 AM
The code come up as a '72 250, Flint plant, used in 1/2 and 3/4 ton 2 and 4 wheel drive whith manual trans.
Bill Burmeister
#221574 12/12/2006 5:29 AM
Junior Member
Junior Member
I ALSO NEED HELP ON AN ENGINE CODE, IF YOU CAN
THANKING YOU IN ADVANCE
MY MOTOR NO.,013125EF54Y
#221575 12/12/2006 8:33 AM
Longbox, Thank you. Was kinda hoping to find another 292 maybe but sure didn't want the 230, so this is good. This motor is closer to home and costs even less so things are just dandy..Thanks again
#221576 12/12/2006 12:01 PM
Jerry,
Turn off your cap lock. You'll get a better responce.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
#221577 12/12/2006 3:18 PM
F54Y and F54YE are 1954 235 cubic inch Powerglide engines (hydraulic lifters) made in Flint, Michigan (1500 series Panel Delivery).
EF54Y is not in the truck ID numbers book that I have. Maybe someone else has better information that includes 1954 passenger car engines.
Tim
#221578 12/13/2006 5:27 AM
Hi All,
Here is some engine serial number information for Chevy Trucks and Cars.
Cheers!
