4 members (Gdads51, cmayna, FAST55, Gray_Ghost), 113 guests, and 0 robots.
Topics128,111
Posts1,056,258
Members48,437
#221567 12/12/2006 3:57 AM
Junior Member
Junior Member
When you are bolting a rear fender to the box, does it need a gasket or something. It appears that there was something between the two before,similar to a gasket. If so, what is it called? What is welting?
#221568 12/12/2006 4:06 AM
I'm not sure which year you are referencing, however there is fender welting on the '60-'66 Chevy truck rear fenders.
#221569 12/12/2006 6:10 AM
actually...there's both gaskets and welting. I used the welting on mine with no gasket. Figger the welting will do about the same job and looks good. Be sure to notch the welting at the bolts or they'll never go down to the edge of the fender.
#221570 12/12/2006 1:32 PM
The 47-55 Factory Assembly Manual does not show any "anti-squeak" (welting or gasket) on pickup rear fenders (it was used on all front fenders). There is, however, fender welting used as anti-squeak on rear panel-body fenders (Panel Truck, Carryall Suburban, an Canopy Express).
Nonetheless, as Jim Carter states, rear fender welt is non-original a "popular extra".
Tim
