| | | Forums66 Topics128,035 Posts1,055,566 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 35 Apprentice | | Apprentice Joined: Nov 2006 Posts: 35 | Right. I've done a search in the forum about ball joints, and nothing is covering my specific issue -- removing the original upper ball joints! I've been using really big hammers, chisels, drills, oils/lubrications and a lot of explitives, and NONE of it is getting these dang things out. What in the world is holding these things in??? I don't wanna use heat because I'm afraid that it would weaken the control arm. One of my military maintenance tricks is to drill through the entire rivet and then try to knock it out, making the rivet collapse on itself, but even that isn't working right now, and I don't want to drill the holes any bigger for fear of enlarging the original holes. Any ideas? A friend of mine wants to take a really big drill bit and take out the center of the ball joint!!! Help me save my truck from him! One thing I was wondering is this: if I were to find a way to press the old rivets out by force, would the rivet itself come out or is the concept of pounding on it to remove the ball joint along with the rivet at the same time?.
If practice makes perfect, and nobody is perfect, then what's the point of practicing???
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I take it you have removed the ball joint stud from the spindle. After you drill into the rivet it should come out. You can drill up to the size of the replacement bolts. I think its 5/16 in. I always use a cutting torch. If you are careful you do not get the arm hot. Ther are 4 rivets . If you drill them there is no reason it won,t come out. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2006 Posts: 35 Apprentice | | Apprentice Joined: Nov 2006 Posts: 35 | YAY!!! I guess all of my pent-up frustration did me some good. Right after I posted this thread, I went out and beat on it some more and presto! They popped right out! YAY!! Thanks for the advice anyway, Wrench! (Kinda funny how elated one can get when something so simple goes right after fighting it for so long, isn't it?)
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | hey dearth you may want to look at this mod:: http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=003275#000000
shipwright also had done this and loves it
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Aug 2006 Posts: 59 Member | | Member Joined: Aug 2006 Posts: 59 | Dearth, Are you planning to add p/s and disc brakes to your 65? If you are I've got the perfect donor truck for ya. An 83 c-10 with all the parts that you will ever need. I'm only 30 miles from seymour johnson. The price is cheap and complete and runs great. 6 cyl. George Hood
1965 C-10 fleetside shortbed BLACK 82 c-10 longbed 6 cyl. 58 Lincoln 2-dr coupe Black w/white & blk. 59 lincoln 4-dr. parts car
| | | | | Joined: Nov 2006 Posts: 35 Apprentice | | Apprentice Joined: Nov 2006 Posts: 35 | Well shoot! I had already purchased all of the parts and pieces that I needed to upgrade the front to disc. Thanks anyway tho! As a matter of fact, I would have replied to your post the same day, but I was in the process of bleeding the brakes out and adjusting the proportioning valve! I'm so close to on the road I can't stand it!
