3 members (NH46COE, Hotrod Lincoln, 1 invisible), 111 guests, and 8 robots.
Topics128,077
Posts1,056,031
Members48,433
Have been watching for the past several months, ongoing series of chassis modifications of editor's AD truck in "Classic Truck " magazine. Can anyone tell me, if these are unique to the 47-55 chassis, or can these same products be applied to the 41-46 frame? I understand all of you may not have seen all these issues, so I guess I'm asking can you put 47-55 components in a 41-46 frame? Or are they really significantly different?
George
A lot of the stock items were interchangeable... like the front axle, so it stands to reason a lot of the aftermarket units should be interchangeable to. That is not to say that they will not require any extra effort to install them.
Having owned a '50 1/2 ton and a '46 1/2 ton I can say that there weren't a lot of parts that were interchangeable between the two.
Not to say that there aren't some common parts, but i'd expect those common parts to be the exception and not the rule.
