Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Ponchogl, Otto Skorzeny, truckernix, TooMany2count), 122 guests, and 1 robot.
Topics128,277
Posts1,058,453
Members48,490
#220873 12/02/2006 5:52 AM
With the Thrift heaters is it possible to get cold air to the defog/defrost ducts at the windshield. With the fan on and the knob to min. air flow I still get hot air. Is that how they were made to work?
Did you turn off the heater water valve?
•1952 Chevrolet 3800 pickup
---All pictures---
With these heaters all the air still goes through the core, so if you want cold air to pass you have to close off the water. The stock "Ranco" valves really don't close it off all the way, even with a rebuild.
Paint & Body Shop moderator
I'll need the heater from now till spring--then I'll look for those valves and see how it goes.
Thanks!
Mine is on the water pump. You should have one somewhere on either of the two hoses going to the heater, if not one on the pump with a heater hose on it.
---All pictures---
