| | | Forums66 Topics128,274 Posts1,058,435 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 46 | I know that this is a little out there but, like many other bolters I have other chevys and I'm trying to replace the door window glass in my '62 Nova. I got the remains of the old glass out and removed the channel and rubber liner out of the door but I'm looking for advice on installing the new glass in the channel. I found no evidence of adhesive in the rubber. Do you pull the rubber off the metal channel, or try to press the glass into the rubber while on the metal part?? My original shop manual tells me all about how to remove and replace the window assy. but not how to put the new glass in it!! Any help would be appreciated very much. Thanks - Jeff
220 - 221 whatever it takes
| | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | I took my 38 to the local auto glass shop. You want to make sure there is no glass left sticking to the rubber. It can crack the new glass if there is.
| | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | I took the glass to my local glass shop and he put a new piece of rubber on the bottom of the glass an installed it in the metal track for the glass. Worked like a charm and took him all of about 3 minutes.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: Sep 2004 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 46 | Thanks 41 Chevy and Tiny. I wish I had done that first.... After taking no time to think, I got some soapy water and lubed it good, put the rubber part on the glass and then tapped the channel on with a rubber mallet...didn't work too bad until I noticed that I put it on the top of the glass!!!!So I swore alot, took it back off, screwing up the rubber in the process, swore some more,had to get help from my amazing wife, called my local auto glass shop who were real nice but had no channel to sell me, and put it back on and installed it. It ain't perfect but will get me through until spring and I can find new rubber for it and do it all over again. The moral of this restoration adventure is after towing a classic car or truck 3500 miles across the country to a place that they are even more rare and therefore even more worthy of our efforts Don't fire up the new string trimmer near old(or new) vehicles!!! Thanks again for the response unearned sympathy welcomed Jeff
