0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 38 Junior Member | | Junior Member Joined: Sep 2006 Posts: 38 | Hey guys....Did the checking on the VIN #s for both of my trucks. My '48 2-ton checks out.
#1RWD2526....Flint, Mich, 2-ton, 161" WB, 2526 production #.
My '49 4400 parts truck, or what I was told is a '49 has me a little confused.
VIN# 56KC2313....Looked it up in the Stovebolt Decoder, the KC code shows it to be a '40 half ton. American Classics decoder shows it to be a 1-ton of unknown year. Frank Andersons decoder shows it to be a '56 of unknown model built in Kansas City.
I know its a parts truck, but I'd still like to know more. It's definantly an AD 4400 series.
(PS...American Classics showed my 2-ton 6400 to be a "flat face or windshield cowl")
Rezman
Snapoff brand tools .................................. 1948 Chevy 6400 1949 Chevy 4400 (parts truck)
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | First, these are serial numbers, not VIN numbers. VIN is a standardized system that did not exist when these trucks were built.
My experience is that the Stovebolt decoder is the most accurate of those online. I don't get paid or recieve brownie points for saying so, it just seems the most complete understanding these numbers.
The next thing to be aware of is that many of the online decoders ignore big trucks like a 4400 and so far I've not seen one that would recognize a Canadian or other non-US serial number.
The other thing all these decoders do is evaluate the serial number you plug in. They can't tell if someone has swapped the cab or the number plate at some point in the past. You might look hard for evidence someone has changed something.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Rezman, Sounds like someone used the ID plate from a '56 model Stepvan (Dubl. Duty), on that truck. What color, is the background, of the plate. '47-'52 plates, have a black background. '53, & up us a blue background. The '49 4400, should read "SK". | | | | | Joined: Sep 2006 Posts: 38 Junior Member | | Junior Member Joined: Sep 2006 Posts: 38 | Thanks Spanky, I'll check that out and get back with you.
Oldsub, In Oklahoma, that is considered the VIN.
Rezman
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, a VIN is a vin is a serial is a vehicle identification number, don't need to hash that over again, nearly any DMV anywhere calls it a VIN regardless of year
that number is incorrect for a 56 as well - the 55-59 numbers start with the model code, as in [4B] for a 4400, then the year [56] then the plant [K= KansasCity] then the sequence number, which in 56 started at 100001
if that number is on the title, may be a clerical error, if it's exactly like that on a factory tag, somethings fishy!
Bill | | | | | Joined: Sep 2006 Posts: 38 Junior Member | | Junior Member Joined: Sep 2006 Posts: 38 | Well, the tag has a black background and is attached with those hour glass head fasteners. I guess it's very possible that it was semi-parted together. Though it's hard to tell if the cab, or tag for that matter was swapped out down the line somewhere, it does have the incorrect steering wheel. It is an old farm truck after all, and those guys usuallly did whatever to keep those things registered & taged.
Didn't mean to create a fuss, I was just curious. At least my 2-ton matches up.
Oldsub, Spanky & red58, thank you guys very much.
Rezman
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | The number '56KC2313' doesn't appear to fit any Chevrolet numbering scheme i'm familure with.. not for U.S. made trucks made between 1929 and 1959, anyway.
When you enter that number into the VIN Cruncher, what it displays is basically garbage as it attempts to apply known U.S. Chevrolet Truck numbering schemes to your strange number.
In short, Garbage In, Garbage Out.
A actual 1956 truck serial number would be in the form: SSYYF000000
SS = Series, which would consist of a numerical character, followed by an alphanumeric character. Example, '4B' would be a 4400.
YY = Year, the two digit model year. In the case of a 1956, this would be a '56'
F = Factory code.
000000 = Production order number.
If your truck was a 1949 4400, your number would start with a one or two numerical character 'factory code', followed by an 'SK' (which indicates 1949 4400) then a single alpha character production month code, and then a 4 or 5 digit production sequence number.
Example: 1SKK1002
Which would indicate a truck (1) made in Flint, MI (SK) a 1949 4400, (K) in November and was the 2nd truck made that month (since production numbers started at 1001)
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by red58: yes, a VIN is a vin is a serial is a vehicle identification number, don't need to hash that over again, nearly any DMV anywhere calls it a VIN regardless of year
LOL! Thinking the person at the counter of your local DMV understands the definitions is like expecting the the counterperson at your FLAPS to recognize parts off your old truck. Some days you get lucky--most days you're just asking for trouble.
