| | | Forums66 Topics128,035 Posts1,055,447 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 33 New Guy | | New Guy Joined: Nov 2006 Posts: 33 | I received a 1949 3100 that had some body work done on it. I noticed that the vin tag is missing.Is the vin number located on the chassis anywhere and is the vin tag replaceable? It apperars that the title has the engine number as a vin number.
TIGHT IS TIGHT,TOO TIGHT IS BUSTED
| | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | The Vehicle Identification Number (VIN) system wasn't used until the mid sixties. There was a body serial number, but as you noticed, the engine number was used by most states for registration until the mid fifties. The tag is replaceable, but you would have no idea what the original serial number was. | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Back in those days,,the v.i.n. was the same number as stamped on the machined flat surface to the rear of the distributor. The number that you would see on the aluminum plate thats riveted on the hinge pillar when you open the driver door is the body serial number. Thats the way it is,and always has been. Dont let anyone tell you different....Or they can tell you different ,just dont believe it. A serial number and a v.i.n. are two completely different things!! | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | And there were no identification numbers stamped on the frame or elsewhere back then either. | | |
