2 members (elhippie64, 1 invisible), 80 guests, and 1 robot.
Topics128,022
Posts1,055,361
Members48,420
#219919 11/17/2006 2:33 PM
can anyone give me the size i need to build a wooden rolling platform to sit my cab of my 51 chevy on once i remove it from the frame? would like to make it out of 4x4's with h/d wheels to move it around after i get it off the frame
#219920 11/18/2006 12:12 AM
dbone -- when I made mine, I just got underneath and measured the frame rails and made the wooden frame to match.
The can isn't that heavy -- 4x4s are overkill. I used 2x6's (the cab hangs down a little on the outsides so 2x4's aren't tall enough to give you enough clearance.
Hope this helps.
Regards,
~ One of many.
#219921 11/18/2006 12:48 AM
thanks john
#219922 11/18/2006 11:16 PM
Riding in the Passing Lane
I,ve heard tou take 2 skids & put one on top the other works good, although I,ve never tried it.
1972 Chevy c10 Cheyenne Super
#219923 11/18/2006 11:24 PM
Mine is 48 1\2W x 59 long. The cab fit perfect on it. Too bad your not close to me, i'm done with it and don't need it any more.
Wilbur
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
#219924 11/19/2006 4:09 PM
Jusrt made one for myself; it fits perfectly for my 1953 3100.
Size; make it trapezium-shaped with the long/bottom side at 130 cm's, the shorter top is 125 cm's wide and the lenght (front to back) is 105 cm's
Make sure the height of the structure is at least some 50 cm's (easier to work on)and put the wheels on the outer corners for stability.
#219925 11/19/2006 4:30 PM
alright! Stovebolt is going metric before the rest of the country.
"It ain't a truck if you can't hose out the cab."
