Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
5 members (Hotrod Lincoln, Wheelie, Peggy M, Jon G, 1 invisible), 594 guests, and 1 robot.
Topics126,781
Posts1,039,299
Members48,100
Most Online2,175
Jul 21st, 2025
I'm still amazed that after owning my 55 3/4 dually for 13 years, I never stumbled upon this site! I've been reading up a bit and will have some questions and hopefully some answers for others. The truck has the origional 235, heavy-duty 3 speed, a propeller shaft brake and a (I think) 4.59 rear. I found it in 1993 in Temple City Ca. It had a boom lift bolted to a 1/4" plate steel bed. A body shop used it to tow vehicles. They also added half a fender on each side to cover the back wheels. I do think that the medium duty 3/4 tons could come with 7.00-17 wheels as well. Mine had six 16-6 split rims that I changed out for modern rims.
I'm towing a 2500 lb. boat 3 miles to the ramp these days, and the rather steep hill getting there is pressing the old motor a bit. I'm looking at rebuilding and adding some horsepower to the 235 but if I get enough feedback that a 350 and th350 are the only good way to go, I'll have to consider that too. There are a few pics of the truck at Jim Carters site under Feature Trucks from July 2004.
Kim
welcome to the bolt.......we have a lot of folks from your area........enjoy...
Redryder pix
My Hotrod
Ex Hall Monitor
Ex Hall Monitor
Welcome aboard. I have a hard time believing a 235 with a 4.59 rear gear won't pull a boat. I had a 55 1st panel that would pull stumps. A good rebuild would probably be all you need.
Welcome to the site. Rebuild the 235.
Socket Breaker
Socket Breaker
howdy. welcome. glad to have ya here.
-W
id have to agree that a rebuild is what i'd do. so sense hacking up a good stock truck.
it's not old it's "aged to perfection"
http://brent5631.myphotoalbum.com/
Thanks everyone! I've really always thought I'd rebuild rather than replace since I have great respect for my old truck just as it is. I just need to squeeze a few more ponies out of it. Tiny, it pulls the boat fine, it just labors so much on hills. Does anyone know of a first rate machine shop in San Diego?
welcome to the bolt
Cliff59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
obs2kl,
You have a beautiful 55!
From one bolthead to another welcome to this site It is where I turn when I am in question!
Roger
Roger
http://www.flickr.com/photos/45469713@N00/?saved=1
I have never been much of a fan of the 55-59 body style, but your dually has a great look. It looks like a truck.
'67 GMC 3/4 292 4spd
Kim that truck is fine as a frog's hair. There's a discussion somewhere around here on the virtues of those old bolt sixes and how they can be made to produce all kinda horses. In any event, small blocks are cheap and easy to come by so either way you're okay with that fine truck to start with. By the way, what have you done if anything to the brakes and suspension???
Thanks again for the comments, though honestly moving the camera away from the truck makes it look better than extreme close-ups!
Don, your truck and especially your account of the journey home sure "rang a few bells" with me. I couldn't believe how loud it was in the cab and top speed was (and still is) 55 for me too. The brakes and suspension are stock so new lines and all are next on my list.
looks great, I have never seen one before
Redryder pix
My Hotrod
Yeah, I know what you mean. I look much better from far away too. "Time for my close-up Mr. Demille".
welcome to the 'bolt.. smile cool
Another quality post.
Real Trucks Rattle
Beautiful truck man-glad you are keeping it stock... cool
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.048s Queries: 13 (0.045s) Memory: 0.6667 MB (Peak: 0.7699 MB) Data Comp: Zlib Server Time: 2025-09-22 22:22:16 UTC
Valid HTML 5 and Valid CSS
