| | | Forums66 Topics128,154 Posts1,056,838 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 63 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 63 | Was wondering if anybody knows --- will wheel cylinders from a 47 chevy pickup fit on a '51 3600? did the 3/4 tons use heavier brakes? Or was it all standard. Thanks, | | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | To answer your question, no, I don't think so. Pre '50 are Huck style brakes, '51+ Bendix; although this information does not answer your question re: wheel cylinder diameter.
I was reading you "log", instead of paying for a high priced new or rebuilt single master cylinder, go for a dual (safer and it's cheaper too!), it's a good time for it as you will be repacing your brake lines. Do a 'search' for dual master, many here have done it. Welcome and keep us posted!
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Sep 2006 Posts: 60 Member | | Member Joined: Sep 2006 Posts: 60 | Whether Huck or Bendix, all the brake parts are larger and heavier duty on a 3/4 ton. Unless of coarse somebody put 3/4 axles unto the 1/2 ton, as that is not unheard of. The 3/4 ton's need to stop a bigger ( heavier ) load . My huck cyl's were always different fron the Bendix as I have owned both and 1/2 and 3/4. Jon | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | John, You didn't say if the 47 was a 3100 or a 3600. If they are both 3600's then the rear wheel cylinders should interchange. A lot of parts catalogs list the same rear wheel cyl. for '46 to '52. 3600's kept huck brakes through 1952. 3100's had huck brakes through '50. Also...3600's through '52 and 3100's through '50 used the same front brakes (huck style) so those parts should also interchange except for the drums. | | |
