6 members (WICruiser, Gdads51, Jay R, 55shaker, Ponchogl, DadsFirstPickup), 129 guests, and 1 robot.
Topics128,054
Posts1,055,782
#218520 10/26/2006 1:57 PM
ever stop and put gas in your bolt and the handle clicks off then ya hear a gurgle as a spash of gas wants back out just to run down the side of ur cab
#218521 10/26/2006 2:30 PM
I hate it when this happens! I have even tried putting the handle on the slowest pumping setting and it still happens.
1965 Chevy Fleetside C10
If riding in an airplane is flying then riding in a boat is swimming...
If you want to experience the element get out of the vehicle!
#218522 10/26/2006 3:30 PM
I listen, and slow it down when it starts to get full.
I use a rag when I'm filling The coupe...
Another quality post.
Real Trucks Rattle
#218523 10/26/2006 3:52 PM
I wait until my gas gauge is at, or slightly below, the half-full mark. Then I put in eight gallons only.
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
#218524 10/26/2006 4:17 PM
When I was young and working at a gas station, I remember that most of the cars would produce a whistle which would let you know when it was almost full. I can't remember whether that was a function of the pump or the car.
1951 1 Ton Completed
#218525 10/26/2006 5:48 PM
When the gas comes up to getting full, I always press the rubber boot against the inlet mouth with the free hand and release the pump lever.
You have to wait at least 10 seconds in that position for all the gas to return from inside the booth back into the tank.
Then slowly pull out the nozzle and with the other hand and a rag catch any remaining drops.
You get used to the procedure after a short while and never have any spills or drips again.
Some pumps still have the old no-booth-exhaust system, then you just gotta press a rag around the tank inlet.
I thought these are outlawed by now everywhere.
On the road every day...
1952 Truck - 235
1948 Coupe - 261
#218527 10/26/2006 8:37 PM
sure takes awhile to get the smell off your hands or out of the truck.......gotta take it slow and easy,, method works on a lot of stuff grin wink
Redryder pix
My Hotrod
#218528 10/26/2006 9:47 PM
I listen to mine also, & put it on slow-only way I have found that works. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#218529 10/26/2006 10:20 PM
I take it slow and also leave the ignition switch on so I can watch the gauge.
Got a separate switch to kill the power to the coil.
Bill Burmeister
#218530 10/26/2006 10:48 PM
I only put in about 10 gal. at a time ,when i take hard right turns I get it coming out the cap ,think maybe my cap is bad. Know the gas smell in the cab it stinks!
Keep em on all fours!
my 72
#218531 10/26/2006 11:12 PM
welcome to the bolt.....
Redryder pix
My Hotrod
