| | | Forums66 Topics128,132 Posts1,056,376 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 29 Member | | Member Joined: Dec 2003 Posts: 29 | who make a complete rebuild kit for the drum brakes on a 59 chevy 3/4-ton? i need them for the front and rear?
'59 Chevy 1-ton '03 **** Lightning '96 Kawasaki 1100 zxi
| | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | Kanter. Go online at www.kanter.com. I would email or call them to verify availability and core charges. Good luck.
Professional Novice
| | | | | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | The Wagner part # for the wheel cylinders F18009 fits 56-59 front & rear Except front axle of 4X4 which is F18290, and F18291 / master cylinder #F21680, the shoes are 12x2 and part #310 hold down kit #F19471 front or back | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | You should be able to buy what you need at a local mom & pop parts store. Go with new wheel cylinders, I've never had any luck with rebuilding. You might have to send your shoes off to get relined, but I'm not sure.
Fred 52 3600 69 C-10
