7 members (Jims46, Otto Skorzeny, dt235sd, 2-Ton, tclederman, Bill Hanlon, Millenimech),
127
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,191 Posts1,057,365 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 22 New Guy | | New Guy Joined: Sep 2006 Posts: 22 | Turns out my new project '57 Big Window was a V8 automatic truck, red with white interior and base level trim.
i got it from some really cool people who started to hot rod it with a nova front clip and a deep C-notch for the rear axle. engine and trans are long gone but the rear is there. all stock frame and suspension pecies were scraped when it was cliped.
now im not sure what direction to take with it, but if its a rare truck i will probably restore it.
'57 Big Window 3100 '53 Five Window 3100
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Snowdog,
If you want to try to determine if your truck had a V8, the VIN can help you (you proably know this), a V in front of the VIN indicates a V8 truck.
However, it looks like there is no way to tell if it was a 265 or a 283 because that code was on the cylinder block (you probably know this).
If it was mine, I would restore it (and try to get a '57 truck 265 or 283 - the first of "small block" GM V-8s). But, do what ever you want - it is your truck.
Tim | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | I think all 57 3100 V8s were 265s, even though the cars were 283, but I've been wrong before. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The '57 1/2 through 1 1/2 tons used the 265 (also base v8 in cars), the 283 was used in 2 ton and larger. There is one issue with restoring it, and that is the fact that the p/o already started to cut it up. Going back to original will most likely require getting an entire replacement chassis. You could go for a comprimise, use the updated suspension, brakes, etc, with a period dressed engine and steel wheels to get an original type look with modern handling and performance.
Bill Burmeister | | | | | Joined: Sep 2006 Posts: 22 New Guy | | New Guy Joined: Sep 2006 Posts: 22 | Tim, yes there is a V in front of the VIN # and it has all the V body trim. how would the block codes read for a '57 ?
Baldy, i had read that the 283 was a late year option for '57 but the tag for the GVW and engine HP rating only list the 235 and 265
Bill, my plan so far is some kind of resto rod, but its a long term project so i'll see what parts turn up along the way.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Baldy & Bill are right. 265 was the only V8 available in 3100 trucks in 1957. | | | | | Joined: Jul 2006 Posts: 34 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 34 | i have a stock 57 shortbed frame for sale but i am a long ways from jersey
FOR EVERY PURCHASE MADE BY A BOLTER I CONTRIBUTE BACK TO THE STOVEBOLT SITE.KEEP ME IN MIND FOR YOUR 47-59 ORIGINAL CHEVY TRUCK PARTS NEEDS. THANKS,JIMBO MY CELL NO. 817-648-3249 "SOME OLD CHEVY TRUCKS MUST DIE SO THAT OTHERS CAN LIVE"
| | | | | Joined: Sep 2006 Posts: 22 New Guy | | New Guy Joined: Sep 2006 Posts: 22 | yea Fort Worth is quite a drive for me, but i did find one closer to me for $175.00 and its a complete rolling chassis.
where can i find a guide to decode engine block #'s
| | | | | Joined: Oct 2006 Posts: 125 Member | | Member Joined: Oct 2006 Posts: 125 | following this thread brings a question to mind. How does one know what transmission originaly came in his truck?? I have a '58 3600 with V at the beginning of the vin. no. ( I think it would have been a 283). ...very interesting and informative all the knowledge passed along here.
'58 3600 350/4-sp/stepside/big window cab '59 3100 235/4-sp/stepside
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I have all the fixins from a 55 2nd series,which should be the same as your 57,I drive truck most of the time so I am hard to get in touch with,but Email me and I will get in touch with you ASAP.Nothing for sale here if you can use it it is yours. | | |
