7 members (Shaffer's1950, David Bush, Hotrod Lincoln, JW51, Gdads51, Gray_Ghost, Gib70),
107
0
Mod | | | Forums66 Topics128,051 Posts1,055,735 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#21740 04/15/2003 8:33 PM | Joined: Apr 2003 Posts: 12 Member | | Member Joined: Apr 2003 Posts: 12 | My 67 Suburban has some "funny" (except not funny at all) symptoms.. Can anyone describe to me symptoms of a clogged fuel line? (In short: she cof(f)s(?) and sputters during a heavy right foot) I can describe it better later.. Right now shes packed for easter, going skiing and such..
ENGINE: 250 TRANS: 3 on the tree Stock driveline.. | | |
#21741 04/15/2003 8:47 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | GM250: Check fuel filter first, then line. Buddy it sounds like filter. Have a nice vacation!!! popcorn The Truth is Out There (Norway Geez I'm jealous) | | |
#21742 04/15/2003 8:53 PM | Joined: Apr 2003 Posts: 12 Member | | Member Joined: Apr 2003 Posts: 12 | Thx for fast reply! If you would like to check her out, shes online.. http://www.cheva.tk Btw, where exactly can I find the filter? havent been doing so much mechanical to her since i bought her last spring.. | | |
#21743 04/15/2003 9:19 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | GM250: There should be one someplace between tank and fuel pump, don't know much about 6's just start looking, alot of the guys have that motor, take line off at carb, have somebody turn motor and see if line is flowing good. That a start! Nice truck!! popcorn The Truth is out There (Ok 6 cylinder guys a little help) | | |
#21744 04/15/2003 10:28 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | There should be a filter in the big fitting where the fuel line goes into the carb. Make sure you put the filter in the correct way(spring goes in first then the filter --hole end of the filter out). The large fitting also has very fine threads and can be damaged very easily when trying to thread it back into the carb so make sure it goes in straight and turns easy.
#21745 04/15/2003 10:31 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | A clogged fuel line will have symptoms such as you describe. Does it cough(coff), sputter then run ok after ??? or does it remain constant or even cough, sputter and even quit running??
#21746 04/15/2003 10:40 PM | Joined: Apr 2003 Posts: 12 Member | | Member Joined: Apr 2003 Posts: 12 | thx for all the good answers guys! She will cough (my mistake, not coff..  ) then run ok for a while, then she weill have her troubles again.. Im gonna check her out after my vacation trip.. Happy Truckin guys.. And Stay away from those F**D's.. Theyre nothing but trouble | | |
