1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 1 Junior Member | | Junior Member Joined: Oct 2006 Posts: 1 | I am looking at changing the ball units with roller units ,does anyone know if these bearings/races can be purchased locally ( napa etc )would you have part #s . Thanks Jeff | | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | I used to have ball bearing woes until I thinned my grease by mixing white lithium and "standard" grease. I packed them (stuffed them) so full that the grease came out past the seals. Since then I haven't had any problems.
delete my account and pictures
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | jeff,
Give the year and model of your truck...ie 55 chevy 1/2 ton. I am sure somebody has the part numbers you are looking for. | | |
