1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 15 Junior Member | | Junior Member Joined: Feb 2005 Posts: 15 | Does anyone know if there is suppossed to be a rubber boot/seal around the clutch fork into the bell housing? I ordered one from the former Chevy Duty and it looks sort of right but when you try to put it on it is all backeards and too wide. (at least for my setup. Thanks very much. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | maine54,
The parts books (specialty) shows one for a '54, but I think they usually fall off or are taken off. The ones I remember were so devastated by grease and grime that we took them off and dumped them in the trash. The setup works fine without a boot....restorations aside!
Stuart | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The ones that I have received do not fit a truck clutch housing. Is the automobile (54-62 235) clutch housing different from a truck's? | | | | | Joined: Feb 2005 Posts: 15 Junior Member | | Junior Member Joined: Feb 2005 Posts: 15 | Thanks all for your replies. I failed to mention that my truck is a '54 1/2 ton. I don't doubt that they have a pretty short life and may be just as well left off. Carolines truck- thanks for the links but all of them are too wide and only the second looks close but like mine it has the fork hole at the wrong end. And TC that is a good question. (Strange that so many dealers think this part will work on the truck.) I just checked the original Chevrolet dealers parts books and there is no listing for a boot until '55 second series. I'm thinking that answers it? Thanks again. Fred dealers | | |
