7 members (55shaker, EchoBravoSierra, 46 Texaco, BarryP, Otto Skorzeny, Shade Baby, Phak1),
159
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,910 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 24 New Guy | | New Guy Joined: Sep 2004 Posts: 24 | do you really need to replace the press in bolts that hold the original front hubs to the front drums when replacing the drums??? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I didn't realize replacement drums didn't come with the studs already attached. Looks like we'll both learn something here.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy guys, the studs locate the drums on the hubs, some original drums are riveted to the hubs, when those drums are removed and new ones put in their place it is not necessary to re-rivet them, so it is not necessary to replace the studs, unless they are damaged, hope that helps. | | |
