7 members (Hotrod Lincoln, Joe H, Gray_Ghost, Forty9, cmayna, JW51, NJC), 82 guests, and 4 robots.
Topics128,064
Posts1,055,860
Members48,428
#217157 10/06/2006 11:39 PM
I have a model year 1959 Apache series 3100 with VIN 3A590100092 and I understand the truck was built in the USA most likely some time in 1958. My insurance company would like to know when it was built. I would also like to know when Chev stopped making the Apache truck as I have not found any information on the 1960 Apache.
Regards
#217158 10/06/2006 11:56 PM
As far as I know 61 was the last year for the Apache.
#217159 10/07/2006 12:30 AM
Welcome aboard Waggy. GM didn't put specific build dates on vehicles back then. Probably the closest you'll be able to get to a build date would be the build/casting dates from the engine and transmission, if the originals are intact. It seem kind of odd to me that the insurance company needs the build date, usually the year listed for the VIN is sufficient. Your VIN is a '59, breaks down as '59 3100, the digit after 59 is probably actually an "O" instead of 0, which indicates that it was built in Oakland,CA. The VIN indicates 6 cylinder, the casting date is by the starter.
On the Apache name issue, that designation was used from '58-'62, with '58-'59 being the Task Force body (solid axle), and the '60-'61 being the Jet Inspired (independant totsion bar suspension).
Bill Burmeister
#217160 10/12/2006 5:24 PM
ICBC (the insuarence company) has what is know as collector plate which save us money. To get collector insurance the vehicle must be original a limited edition over 15 years old, over 25 years or if it is 1958 or older you can also get what is called a modified collector plate. With these modified plate you can change the colour, the moter, the transmissions, everything. As my pickup is a 1959 Model year and was most likely made in 1958 I am not sure if it can be a modified collector or not. Knowing when it was made may help.
#217161 10/12/2006 11:35 PM
Possibly the 92 sequence number would help nail it down. Right up near the front for sure.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
#217162 10/13/2006 3:29 AM
as your truck was the 92nd one off the line [in Oakland, as pointed out], and the model year production started the previous calender year, your truck was undoubtedly built in 58, but for ICBC, it's the model year they go by, not 'build date' - unless you have the original sales papers and can show it was sold in 58
