Mr. Trail-Good Morning to you. Are you looking for the
large GM five lug pattern (5x5" bolt circle)? Do you have an AD truck with the later model fullsize truck crossmember-e.g. too wide? Try looking at wheels from Chevy Astro/GMC Safari vans-they're a wee bit narrower and different offset from the typical full-size pickup wheels. Hope this helps, if I didn't make the right call or you need other thoughts, drop us a line. Happy hunting!
Regards,
Wannabe
