2 members (BC59, Bill Hanlon), 152 guests, and 2 robots.
Topics128,088
Posts1,056,109
Members48,434
#21619 11/01/2004 11:08 PM
On my 454 the crank pulley does not line up with the alt/smog pump/ps/ac pulleys. The crank pulley is about a 1/4" off.
Does anyone know where I can get a pully spacer to put behind the crank pulley to line it up, or do I have to fab one? Can I use washers instead?
Can I fab one from aluminum?
Thanx any help would be appreciated
Dano
69 C10 LWB 250 L-6/3spd
79 C30 Crew Cab Dually 454 V-8/TH-400
"Takes more than a coat of paint to make it at Thunder Road!"
#21620 11/02/2004 12:07 AM
Riding in the Passing Lane
I think I would make a spacer out of an old
pulley. smile
1972 Chevy c10 Cheyenne Super
#21621 11/02/2004 1:36 AM
I've made spacers out of flat aluminum plates, anywhere from 1/4" to 1/16" thick, and used whatever stackup was necessary to make the belts run true. Washers won't support the pulley well enough to prevent wobble.
#21622 11/02/2004 2:24 AM
Z
Z Offline
i once used a puller to slide out the mount a quarter inch.it slid on the shaft.
#21623 11/02/2004 9:35 PM
Can I leave the spacers square, or should they be round? Thanx for the input guys.
Dano
#21624 11/02/2004 9:45 PM
They look a little less "shade-tree" if they're close to round!
#21625 11/02/2004 10:34 PM
I guess that I meant to ask; if there will be crank balancing problems. Do they need to be perfectly round?
#21626 11/03/2004 1:17 AM
That close to the center of the hub, a little out-of-round won't hurt. I turn mine out on a lathe, so they're pretty close to round. I doubt if a +/- 1/16" or more would cause problems.
#21627 11/03/2004 9:14 PM
Thanx for the replies/ideas.
Dano
#21628 11/05/2004 1:54 PM
How do spacers work? Is this not an interference fit on the crankshaft and wouldn't spacers stop it from seating properly?
1951 1 Ton Completed
