2 members (dt235sd, JW51),
204
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,077 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#21619 11/01/2004 11:08 PM | Joined: Mar 2004 Posts: 58 Member | | Member Joined: Mar 2004 Posts: 58 | On my 454 the crank pulley does not line up with the alt/smog pump/ps/ac pulleys. The crank pulley is about a 1/4" off. Does anyone know where I can get a pully spacer to put behind the crank pulley to line it up, or do I have to fab one? Can I use washers instead? Can I fab one from aluminum? Thanx any help would be appreciated Dano
69 C10 LWB 250 L-6/3spd 79 C30 Crew Cab Dually 454 V-8/TH-400
"Takes more than a coat of paint to make it at Thunder Road!"
#21620 11/02/2004 12:07 AM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I think I would make a spacer out of an old pulley.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#21621 11/02/2004 1:36 AM | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | I've made spacers out of flat aluminum plates, anywhere from 1/4" to 1/16" thick, and used whatever stackup was necessary to make the belts run true. Washers won't support the pulley well enough to prevent wobble. Jerry
#21622 11/02/2004 2:24 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | i once used a puller to slide out the mount a quarter inch.it slid on the shaft. | | |
#21623 11/02/2004 9:35 PM | Joined: Mar 2004 Posts: 58 Member | | Member Joined: Mar 2004 Posts: 58 | Can I leave the spacers square, or should they be round? Thanx for the input guys. Dano
#21624 11/02/2004 9:45 PM | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | They look a little less "shade-tree" if they're close to round! Jerry
#21625 11/02/2004 10:34 PM | Joined: Mar 2004 Posts: 58 Member | | Member Joined: Mar 2004 Posts: 58 | I guess that I meant to ask; if there will be crank balancing problems. Do they need to be perfectly round?
#21626 11/03/2004 1:17 AM | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | That close to the center of the hub, a little out-of-round won't hurt. I turn mine out on a lathe, so they're pretty close to round. I doubt if a +/- 1/16" or more would cause problems. Jerry
#21627 11/03/2004 9:14 PM | Joined: Mar 2004 Posts: 58 Member | | Member Joined: Mar 2004 Posts: 58 | Thanx for the replies/ideas. Dano
#21628 11/05/2004 1:54 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | How do spacers work? Is this not an interference fit on the crankshaft and wouldn't spacers stop it from seating properly? | | |
