| | | Forums66 Topics128,265 Posts1,058,365 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 51 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Sep 2006 Posts: 51 | I finally got my '67 Chevy PU completely re-wired. I put in a new gas sending unit.
As soon as I hooked the wire up to the sending unit, it showed what I thought to be the proper amount of gas on the gauge.
Only problem was, I didn't even have a key in the switch, so the switch wasn't turned on.
Isn't the gauge s'posed to read Zero when the switch is off?
If it's working properly, then I am totally pleased.
If it's not, what else do I need to look for?
~ davey 1967 Chevrolet 1/2-Ton PickupIn the Stovebolt GalleryI'm not sure if I was ever as good as I thought I was, but I know I'm not as good as I used to be.I've forgotten more than I ever knew. Okay, where did I put it? A man can never have enough tools
| | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | It sounds like the hot wire to your gauge is not connected to the switched side of your ignition switch. It seems to be connected to an always hot terminal. It should be switched so it's off when the key is off.
| | | | | Joined: Sep 2006 Posts: 51 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Sep 2006 Posts: 51 | Thanks Tiny. I sort of figured that. I don't know much about electrical stuff, so I hired out the rewire job. Maybe I can get David to fix it.
I assume that if it's "always hot", then it's putting a drain on the battery when switched off?
I don't care if it works all the time, as long as it works, and doesn't put any kind of drain on the battery.
Thanks again buddy.
| | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | No problem my friend. It shouldn't be enough of a load to be a problem unless the truck sits for a while. I don't know how much current the gauge pulls. You'd probably be better off to get it wired correctly.
| | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Davey, It seems to me that some GM vehicles ( i don't know if yours is this way) the fuel guage will remain at its last reading when the switch is turned off. But this realy dosn't apply to what you have posted.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Sep 2006 Posts: 51 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Sep 2006 Posts: 51 | Thanks Toyvo & Tiny. I let it sit for a few days to see what it would do. It didn't seem to drag the battery down that I could tell.
If this is the way it's s'posed to work, then that's fine with me.
After all the money I spent on this re-wiring job, I just want it to work like it should.
I'll keep an eye on it, and once again, thanks for your advice.
