4 members (k2handyman, moparguy, dt235sd, Hotrod Lincoln), 71 guests, and 1 robot.
Topics128,049
Posts1,055,678
#215453 09/10/2006 6:50 PM
Hi Folks,
I would like to make my 41 3/4 ton flatbed truck more modern, an nice daily driver. I would like to know what the pros would do on a rebuild with this goal in mind.
Jeff
#215454 09/11/2006 3:50 AM
I
I Offline
As most folks would say depends on time and money.
Do you want it to look stock? Replace the rear end and put in a 235. Do a search and you'll find lots of info on both swaps. This can be done with minimal investements.
Want a big engine and have lots of money? Replace the entire frame and running gear. You can buy a rolling frame from a number of sources, check out Progressive.
Good luck. Do lots of research here before you go too deep.
#215455 09/11/2006 4:12 AM
buy a full IFS kit from Hiedts, fatman ect, pop in a rear end from a 76 chevy 1/2 ton pickup along with the brake system from the same truck, and a 700R4 tranny... bingo!!
the only problem is the 76 pickup wheels probably wont be the same as what you get in the kit.
Another quality post.
Real Trucks Rattle
