2 members (2-Ton, JW51), 67 guests, and 4 robots.
Topics128,055
Posts1,055,783
#215394 09/09/2006 5:50 AM
just curious about the little spring on one end on each of the spreader bars , what's it's function? Hypothetically speaking , if they were not present when I disassembled the brakes would it be catastrophic if they were absent upon reassembly? and with that the old girl is almost back on her feet again , thank you very much for any replies
#215395 09/10/2006 3:39 AM
It's to return the shoe that moves when you apply the hand brake back to the "at rest" or retracted position. Without it you may get a grinding noise if that shoe rubs the drum when the brake is not applied.
Evan
#215396 09/10/2006 3:41 AM
I rethought this and those springs I believe are anti-rattle for the bar itself.
Evan
#215397 09/10/2006 2:54 PM
yes the spring is a rattle spring.If not there it will make noise, also any springs in the brakes should be there just for safety reasons!There is nothing like applying the brakes and nothing happens!
