| | | Forums66 Topics128,060 Posts1,055,840 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 55 | just curious about the little spring on one end on each of the spreader bars , what's it's function? Hypothetically speaking , if they were not present when I disassembled the brakes would it be catastrophic if they were absent upon reassembly? and with that the old girl is almost back on her feet again , thank you very much for any replies | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | It's to return the shoe that moves when you apply the hand brake back to the "at rest" or retracted position. Without it you may get a grinding noise if that shoe rubs the drum when the brake is not applied.
Evan
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I rethought this and those springs I believe are anti-rattle for the bar itself.
Evan
| | | | | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | yes the spring is a rattle spring.If not there it will make noise, also any springs in the brakes should be there just for safety reasons!There is nothing like applying the brakes and nothing happens! | | |
