| | | Forums66 Topics128,056 Posts1,055,803 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2000 Posts: 11 Member | | Member Joined: Mar 2000 Posts: 11 | anyone out there attempt both the newport engineering electric wiper upgrade along with the custom autosound radio in a 55-59 chevy? i've made adjustments on the wiper bracket but the rear of the radio still hits the bracket making the radio not line up with the mount in the dash. thanx in advance. db | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I put a Newport wiper and modern radio [fergit the brand, but AM/FM/CD provision] in a buddys 56 panel a few weeks ago and it all fit ok ... I left off the brace they supply to hang the radio from the wiper support, thing don't weigh but a few ounces
Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Did the same here. I am running the Newport and Custom Autosound combo. I don't have any fitment issues. Which radio are you using? I have the USA-04, which doesn't have the extra brace. The fit is a little tight, but doesn't cause any problem. The only problem I have is the wireing connector fits a little loose, and gets a bad connection when I fool aruond under the dash.
Bill Burmeister | | |
