2 members (IHPWR, Otto Skorzeny), 147 guests, and 1 robot.
Topics128,157
Posts1,056,878
Members48,458
My 1951 PU truck has the stock 16" steel wheels. I am planning on buying new rubber (tires), can these old style wheels (rims) be used with tubeless tires without installing tubes inside?
Best Regards
Will
Heck, no. But you can run tube-type radials, which would be a fine upgrade while retaining the original rims.
1951 3800
-hotshoe
A lot of people are running tubeless radials on old wheels. Do a search.
I just had tubeless radials mounted on my 16" steel wheels for my '51 pickup. No tubes needed and no leaks.
I should say, however, that my wheels were in excellent condition. The rivets were all tight and they had recently been painted. Also, it appears that they had sprayed clearcoat on the inside surface of the wheels.
Been running modern tubeless radials on original 16" rims for years with no problems.
1950 Chevy 3100
261, 4 speed
Purchased 1977
1964 Pontiac Lemans Convert
