1 members (moparguy),
39
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 6 Junior Member | | Junior Member Joined: Aug 2006 Posts: 6 | I am looking to put the sheet metal from my 1939 chevy on a more modern 70s - 80s frame and drivetrain any one have any info | | | | | Joined: Jun 2005 Posts: 168 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 168 | I hear S-10's are about the same dimensions as the pre-AD trucks
Liquidated my projects Now looking for a decent '47-'55.1 3100, 3600, or 3800
| | | | | Joined: Apr 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 127 | i saw a 46 on an s 10 chassis, it was unfinished, but the frame was wider than the front of the cab cowl. i don't know how or if it ever got finished, but that 39 has a very narrow nose compared to the s 10. if it's been done i'd like to see one. wahoo40
Just because you have a few Craftsman tools, it dosen't mean your a craftsman.
| | | | | Joined: Jun 2006 Posts: 110 Member | | Member Joined: Jun 2006 Posts: 110 | Putting a 38 on a s10 chassis and so far it is a good fit. Do a search on this site and the HAMB for "s10" and frame swap and you will pull up a lot of information. I have seen 36 - 55.1 along with numerous cars swapped onto these frames.
Jim
Good luck with your project!
Jim
| | | | | Joined: Aug 2006 Posts: 6 Junior Member | | Junior Member Joined: Aug 2006 Posts: 6 | Ok A simple Question from a simple guy Why does every one use S10 frames and not a chevy 1500 or 2500? they are alot easer to find. | | | | | Joined: Jun 2006 Posts: 110 Member | | Member Joined: Jun 2006 Posts: 110 | resto pack info has frame, tread and wheelbase info... and a whole bunch more. http://chevy.tocmp.com/chevyresto/index.htm
Jim
