5 members (Phak1, Hanks custodian, walter74, Charles in CA, baldeagle), 164 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#214671 08/29/2006 10:35 PM
Junior Member
Junior Member
I am looking to put the sheet metal from my 1939 chevy on a more modern 70s - 80s frame and drivetrain any one have any info
#214672 08/30/2006 12:11 AM
I hear S-10's are about the same dimensions as the pre-AD trucks
Liquidated my projects
Now looking for a decent '47-'55.1 3100, 3600, or 3800
#214673 08/30/2006 1:20 AM
i saw a 46 on an s 10 chassis, it was unfinished, but the frame was wider than the front of the cab cowl. i don't know how or if it ever got finished, but that 39 has a very narrow nose compared to the s 10. if it's been done i'd like to see one. wahoo40
Just because you have a few Craftsman tools, it dosen't mean your a craftsman.
#214674 08/30/2006 1:26 AM
Putting a 38 on a s10 chassis and so far it is a good fit. Do a search on this site and the HAMB for "s10" and frame swap and you will pull up a lot of information. I have seen 36 - 55.1 along with numerous cars swapped onto these frames.
Jim
Good luck with your project!
#214675 08/31/2006 4:24 AM
Jim
#214676 08/31/2006 10:27 PM
Junior Member
Junior Member
Ok A simple Question from a simple guy Why does every one use S10 frames and not a chevy 1500 or 2500? they are alot easer to find.
#214678 09/01/2006 1:19 AM
http://50chevy.freeservers.com/Suspension_Widths.html#Suspension
http://www.chevytrucks.org/tech/ifs&rearend.htm
http://www.enjenjo.com/tech.html
I've been measuring and sketching, so far the S10 long wheel base regular cab is the best fit. I've been hoping to find something to drop my 50 1.5 sheet metal on and I'm currently at a loss most late model (72-on) are too wide. Current plan is to mod late model parts to fit the stock frame which is in very good condition. Grigg has great info on this.
Jim
#214679 09/01/2006 1:40 AM
resto pack info has frame, tread and wheelbase info... and a whole bunch more.
http://chevy.tocmp.com/chevyresto/index.htm
Jim
