| | | Forums66 Topics128,077 Posts1,055,932 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 18 Junior Member | | Junior Member Joined: Feb 2004 Posts: 18 | I have located a very nice 52 GMC, 5 window, 1 ton. The 5 window is a priority to me, but my ultimate truck is a 1/2 ton. What are the differences from the 1 ton to the 1/2 ton on the body (I plan on getting a new under carraige anyway)? Could I get a 1/2 ton frame (undercarraige) and drop the 1 ton cab on it? Also, are the Chev and GMC boxes and fenders the same?
Thanks az | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The one ton pickup is often the more desirable of the pickup trucks. I have a 52 Chevy 1 ton pickup and would never trade it for a 1/2 ton. If you want a truck to use keep the 1 ton, if you don't need a truck then the 1/2 ton may work for you.
If you have to, the cabs are all the same until the really big trucks, the tractor trailer size ones get bigger. For the 1/2, 3/4, and 1 ton, all of the sheet metal is the same, with the obvious exception of bed and running board length. Fenders, hood, grill, and running boards change, but are the same for the 1.5 and 2 ton. The GMC trucks bigger than 2 ton have larger fenders and such, and eventually, the biggest ones everything is different.
I would hope you could leave the 1 ton together and find a suitable 1/2 ton if that is what you have to have. You could probably trade someone for a 1/2 ton if you asked around here. If I had a 1/2 ton I would trade for a nice 1 ton in a heartbeat.
Good luck, Grigg | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | one point of view only............count the half ton on the road or at meets.........you got your answer.. but if you wanna haul stuff then your one ton might be the winner Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | If that 1 ton, is indeed a 9 foot box pickup. It's a "Rare" truck. I wouldn't forsake it, for a more common 1/2 ton pickup. | | |
